Saltar al contenido principal
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
Preguntas 132 Ver todo
red x on battery
my Samsung tablet wont charge and there is a red x on the battery logo
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
7 Respuestas
Respuesta Más Útil
Change the charger and leave few mins to start charging
Fue útil esta respuesta?
Puntuación 1
I had the red x problem with my tab 12.2 even though I was using original/correct 5.3 volt charger and cable (compared to Galaxy Note 4's 5.0 volt charger). The solution that worked for me;
With tablet on and unplugged, hold down power button briefly enough (so not to turn off tablet) to plug in cable, then release power button. No red X. The bummer part is that I need to do that every time I want to plug in power while using. Luckily a very simple solution, but it would be nice if it would just work plugging it in. For me... it use to be able to charge just plugging in, not sure what made that change.
Puntuación 1
1 comentario:
I have a better solution, replace the charging port. I have had no problems since I have replaced it.
- de
Red x problem tried everything only thing that work is the turn off then plug the charge in and it charges .Samsung should fix this soft wear problem
Puntuación 1
The red x means that you are trying to charge with a charger that reads as a usb cable connected to a computer. So its either you are charging through PC or you need to change the charger
Puntuación 0
Masalah red X battery tak boleh cas
Puntuación 0
1 comentario:
- de
maybe your battery is weak you need to replace it or try to reheat the ic inside the battery upper head its der the ic of the battery
Puntuación 0
The red x on a Samsung device means that you charger is broken and it will charge way slower.
Puntuación 0
Añadir tu respuesta
glenn brady estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 5,876
