Mac Pro Airport (WiFi) inquiry
I was wondering if I could put my MacBook (older white plastic model) into my Mac Pro desktop which does not have airport in it.
Es esta una buena pregunta?
Don't see any way that you could do that. ;-{
Can you give us the last 4 numbers of your serial number so we can identify which Desktop system you have. Depending on what you have it maybe a simple fix.
Open your system up and looking just under the second fan unit on the main logic board you should see a connector and a few cables held to the side. Here's a good image on what you should see (minus the AirPort card): AirPort & BT boards.
If its enmity you can put in an Airport Extreme Card P/N: 661-4060
Otherwise, you'll need to use an external USB WiFi adapter.
Fue útil esta respuesta?
Full serial: G871022XUQ2
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 146
1 comentario
Mac Pro - Quad Core (Original)
- de Dan
