Saltar al contenido principal
Information and repair guide for the Samsung RF220N*TA** refrigerator—a 2014 bottom-mounted freezer model with French door access and compact design, suitable for built-in usage in limited spaces. This page covers information for model numbers matching the pattern RF220N*TA**.
Preguntas 3 Ver todo
Why are my fridge and freezer not cold enough?
We noticed about two weeks ago that our 3 yr old Samsung Fridge, model rf220nctasr, is not cold enough (both fridge and freezer). Since then, we replaced the evaporator fan and cleaned the condensor coils. No change.
Other observations:
- The condensor fan seems to function adequately. It does sometimes run even if the compressor doesn't (we noticed that once).
- The compressor is really hot to the touch.
- The evaporator fan runs and pushed cold air when the light in the freezer isn't on. Can't confirm if it stops working however.
- The evaporator coils are not evenly frosted.
- We do not hear any clicking noise.
- Self diagnostic returns no error.
Repair person seems to think we should replace the freezer evaporator and filter dryer, but from my research, if the evaporator was defective, there would be an ice build up ?
Thank you!!!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The key symptom is the hot compressor. My first thought would be low refrigerant level and this requires a licensed technician.
Here's how to check it out:
https://fridgeman.wordpress.com/2008/06/...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
sindyhoule estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 3,443
