ipad is disabled connect to itunes.
ipad is disabled connect to itunes. how to solve this ?.
Es esta una buena pregunta?
hello ajishra,
1) Disconnect all cables from your device.
2) Hold down the Sleep/Wake button, then "slide to power off" to turn off your device.
3) Press and hold the Home button and plug the device into your computer.
4) Continue holding the Home button until you see the Connect to iTunes screen.
All data will be lost
Fue útil esta respuesta?
Great, thank you very much!
Work!!!! thank you
after that what do you do because my screen just showed connect to itunes screen
Thank you!!!
will all photos apps and ID passwords be lost??
Hold down the "Sleep/Wake" button on your iPad for a few seconds until a red slider appears. Slide it to shut down the iPad. Hold down the iPad's "Home" button and connect the sync cable to it while you are still holding the button. Don't release the "Home" button until you see a screen that says "Connect to iTunes."
What if I do not have iTunes nor a computer?
not to be mean but you know that he/she just copied safari and safari just added what ever is on apple
works wonderfully, thanks!!
What if I don't have a computer?
I don't have computer
Not an answer but holding down the power button does not produce the slider. Still have the iTunes icon showing,
so look at my school when it does that they take the old one I had and replace with a new one that's why I don't let kid hold my things
i doing all that and still comes i pad disabled connect to i tunes
Im in the same position. No matter what i do it return to connect to itunes?????
Due to the repeated entry of the wrong passcode, your ios device may be locked, you can refered to this article:
It says iTunes on the screen and nothing hapens.
What do I do next
Thank you so much, I’ve been unable to use my Ipad for months as I’m far away from an Apple Store. Tried all sorts of things, nothing worked. This fixed it in minutes. You’ve genuinely made my day.
How do you connect to iTunes when the screen tells you to
My iPad is locked (disabled )
Remove Screen Lock
plz Answer my question
@montyorkay YEAH SEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Why you want to connect your iPad to iTunes? Are you trying to factory reset your iPad? If so, maybe you can use other tools to solve this problem:
icloud:
You can go to icloud and enter your Apple ID and passcode, then select the device you are using and choose to erase all data.
third-party software:
Some paid software such as joyoshare ipasscode unlocker can also help you bypass password on ipad.
Maybe you can solve the problem after trying the tools above.
please open window apple ipad
Hello, if your iPad has become disabled, your only choice will be restore it to factory settings, it also means to completely erase the device.
If you’ve set up Find My iPad, then the easiest way to reset your iPad is through iCloud. Just log into iCloud.com and click Find My iPhone, choose your iPad and click the Erase iPad.
If you haven’t set up Find My iPad, but backed up your iPad wtih iTunes, then you can connect your iPad to the computer and restore iPad using iTunes.
If you don’t have an iTunes backup or disable Find My iPad, then you can try third-party tool like FoneGeek iOS System Recovery to unlock disabled iPad.
For detailed steps on how to fix disabled iPad via iCloud, iTunes and third-party tool, please refer to this guide: iPhone/iPad is disabled connect to iTunes.
Same Problem. I think you have to put the device in recovery mode first and then restore it from there.
how do you do recovery mode
When co.es the iTunes I love it like that ?
how is this an &&^&^$^ solution's when all data will be wiped &&^&^$^ apple
Still didn’t work for me just went back to saying error and then on my iPad it went back the the screen saying IPhone disabled connect to iTunes.
you are getting this error iPad disabled connect to iTunes because you attempted to unlock the iPad with the wrong password multiple times.
You can also check out other methods to restore the iPad without any data loss from here. Also, you can try third-party tools like FoneGeek iOS System Recovery.
Hope you find the answer helpful.
If there’s something wrong with your itunes, iMyFone TunesFix will be a good choice for you to solve itunes errors and issues.
More than 100 itunes errors can be fixed: install/connect/restore/backup, and etc
What’s more, the repair will not cause damage to your data on the device.
It’s fully compatible with itunes 12.5.3.16 and later versions.
More details and step-by-step instructions can refer to the product website.
Like Ferlito, my locked iPad was never synced to iTunes, so Texas Mac Man's instructions did not work. Apple gives the following instructions to completely restore your iPad (which will erase all contents):
* Disconnect the USB cable from the device, but leave the other end of the cable connected to your computer's USB port.
what if ipad doesnt connected to iTunes screen?
aineetan@784gmail.com
thankz a lot ........
If the iPad cannot connect to iTunes after entering the wrong password multiple times, then I would suggest you contact Genius. In addition, RecoveryTool iPhone Unlocker is also a solution to try.
What does it mean when you lpad make a whole said something is wrong with my iPad 2 mins is not enough jane in a few hours on the card I have a few more ➕ battery
What?????????????????
Ultimas 24 horas: 161
Ultimos 7 días: 1,265
Ultimos 30 días: 6,119
Todo El Tiempo: 568,488
Also, I have the same problem too but, when I tried connecting my USB to the Ipad, it didn't do anything.
- de This channel’s videos are Old
How you Do THAT way
- de Rakiem Wrighton
I just brought an iPad from fb and I turned it on it says “iPad is disabled” so I tried connecting it to iTunes and it says “iTunes could not connects to the iPad “iPad” because it is locked with a passcode. You must enter your passcode on the iPad before it can be used with iTunes.”
- de jaydeylamsam
You not gonna be able to do anything unless u get that info from who u bought it from should of checked it before buying
- de Ashley Valdes
yea but i'm still confused
- de Layla Diggs
Mostrar 18 comentarios más
