Why wont my cell charge
ccant charge cell how can i tell if battery dead
Es esta una buena pregunta?
Usually, the issue is the charger, the charger may be damaged and you may need to use another charger, in some cases, it may just be built up dirt in the charger port (My issue).
I stopped this issue by using something small enough to get all the dirt/dust out the charger port. it then worked.
Try another charger, a wire in the charger may be damaged.
Have you dropped it? if so their mat be a loose connection on the motherboard or the battery has been damaged!
If this has worked please vote my answer and accept.
Thanks Ryan
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 39
What model phone is it and what have you tried?
- de oldturkey03
