Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Pantalla iPad Mini de 7.9 pulgadas, con 16, 32 o 64 GB de almacenamiento.
Properly Testing Home Button
Greetings,
I recently purchased a new digitizer with IC and Home button for iPad Mini.
I attached the digitizer cable (but didt fix both LCD and digitizer) and it looks like it works fine except the Home button, which clicks (I hold it by fingers), but no reaction.
My question is if it should work in such 'detached' state, i.e. is my digitizer Home button broken?
Please note the Mini lacks both LCD metal plate and logic board metal cover.
Thanks.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
It should work, even detached. It doesn't have the metal pins like the larger iPads to make contact with. Just be careful not to press it too hard, or it will damage it. Or, you can hold the back of the button for support and press the button.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thank you, looks like the logic board is faulty :(
- de
Añadir tu respuesta
Maaaah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 172
