Saltar al contenido principal
El Nintendo Wii U Pro Controller es un controlador de videojuegos producido por Nintendo en 2012 para la consola de videojuegos Wii U.
ZL Button is sticky - not working
My Nintendo Wii U Pro controller has what seems to be something sticky inside the ZL button. Beyond the complete teardown video, which doesn't go in to much detail about specific parts. Can someone walk me through this fix?
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
3M Electronic Equipment Cleaner CL600 - Cleaning spray CL600
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Hi Erik. Thanks for the reply. Do you have experience using this product on a button like this? I googled the 3m product you mentioned, and from what I am reading, this would be an off label use. I'm leaning more in the direction of opening the controller and, my original plan was to clean the components with isopropyl alcohol swabs. Perhaps, this 3M cleaner is more adviseable? I ordered the correct tools from ifixit tonight, so I have some time...
- de
isopropyl alcohol swabs work when you need to remove some liquid left in the device. 3M cleaner should help to remove stickiness.
Either one should work fine. Together should work even better.
- de
Añadir tu respuesta
mashieman1 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,025
