My Tamagotchi is still not working after a battery replacement?
I put a new battery in but it is still not working, so what else can I do so it can work and be played?
Es esta una buena pregunta?
The mains problems with tamagotchis are :
Hope it will help someone
Fue útil esta respuesta?
My tamagotchi is only 6 months old (the base). I had put a battery in, but it didn’t work still. I had put it in correctly and it still wouldn’t work. I had used a maxell battery
I suggest making sure you inserted the battery in the right direction. I know this sounds like a simple thing, but someone I know did a similar mistake and ended up throwing it away when the solution was so simple.
Maybe reput the battery’s in if not get a box of new battery’s so it will work better 👏👏👏
So this might be a bit obvious, but if your battery has a sticker take it off unless it says otherwise, because I didn't and i spent AGES trying to figure out what was wrong and then my dad came and took the sticker off and then it started working. So yea
Ultimas 24 horas: 8
Ultimos 7 días: 37
Ultimos 30 días: 215
Todo El Tiempo: 7,954
3 comentarios
Seriously, what is the gadget you're talking about? Are you sure that the problem is the battery only? Please complete questions so that you'll receive helpful answers.
- de blanchell
set it on fire....................................................
- de Michael O'Neill
Why won't my tomogotchi work?
- de Lilly Allen
