Saltar al contenido principal
Anunciado en febrero de 2005, la Canon PowerShot A520 cuenta con un sensor de 4.0 megapíxeles con una lente de zoom óptico de 4x.
Preguntas 12 Ver todo
Change the batteries , A 520
After inserting a brand new batteries or fully recharged 2700mAh NiMH , it still shows "Cange the batteries"?!After a few attempts it starts work just to take 3-4 pictures , then dies again , and so on.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Solución Elegida
sounds a little bit like an old powershot problem.
you could try a workaround (click)
you can also use your preferred search engine and search for: powershot toothpick trick
good luck
Fue útil esta respuesta?
Puntuación 0
Because this model of camera only uses 2 batteries, it literally eats them, as the flash cannot be permanently disabled. I have the same model of camera. Best to check your new batteries or rechargeable ones with a volt meter, they must read better than 1.5v, or the camera won't like them. My rechargeables only lasted 1 year, still good, but not good enough for this model of camera.
Puntuación 0
Añadir tu respuesta
Tchavdar Simeonov estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 4,534
