Saltar al contenido principal
El Samsung Galaxy Note II es un teléfono inteligente que destaca por la combinación de una pantalla grande y un software optimizado para un lápiz óptico auto almacenable integral.
Cannot connect to wifi
my phone's wifi is not working
my wifi signal strength is very strong but it's not able to connect
the status shows obtaining IP address
and after a while it tells network disabled. Poor connection
I checked on the net they say it's because of the update of the phone original version 4.1.1 to 4.1.2 jelly bean, the update is causing the phone wifi connection go crazy
I checked for the solution, in many forums they showed to change the IP settings from DHCP to Static which I did and then after entering the wifi password there is no save option
I tried this way too..the link is below
https://www.youtube.com/watch?v=zyO66lqT...
the first way is dialing *#0011# but it's still not connecting
the second way was too confusing so I didn't try
I checked it online and I guess this problem does not only happen in note 2 but almost all the android phones
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
1 comentario
I have the same problem suddenly in a day. I reset my phone once and I downloaded the wifi fixer, diff., versions, it just does not work.
- de
Agregar un comentario
6 Respuestas
Respuesta Más Útil
my phone is not connecting to wifi and bluetooth
Fue útil esta respuesta?
Puntuación 1
Hi Smriti
Have you thought about the wifi antenna being faulty and to try a replacement?
Puntuación 0
2nd Rssi is not available
Puntuación 0
disconnect then put your password back in. that what i did.
Puntuación 0
I can not connect wifi in my mobile
Puntuación 0
I would recommend replacing the WiFi antenna.
Puntuación 0
Añadir tu respuesta
Smriti Sharma estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 25,582
