Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1502 / 2.6 GHz (Turbo Boost hasta 3.1 GHz) o 2.8 GHz (Turbo Boost hasta 3.3 GHz) procesador Intel Core i7 de doble núcleo con 4 MB de caché L3 compartida.
Where is located the screen backlight fuse?
After a liquid spill, I've cleaned the motherboard and connexions. Everything worked fine for some time but the screen started to blink and went dark a few times until it got dark permanently.
Anyone can point me where the screen backlight fuse is located in the 13" retina mid 2014 model?
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
2 Respuestas
Solución Elegida
Roy Lopez, that would be F7700 which is a 3 A 32 V fuse in a 0603 package. This "screen started to blink and went dark a few times until it got dark permanently." does not sound like the fuse. You do want to check a bit more. Of course, check the fuse first.
Fue útil esta respuesta?
Puntuación 6
Pin 1 of LCD connector is probably &&^&@@.
Puntuación 0
Añadir tu respuesta
Roy Lopez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 5,379
