My beats pill dont work
my beats pill 1.0 was working yesterday, i plugged the charger on it , when i removed the charger it doesnt turn on and the charger usb is lighting red even the charge is not plugged on it
Es esta una buena pregunta?
You can try charging it form a computer. If that helped, your charger is faulty.
Also, here's the way to reset it, in case charging still doesn't work.
Press and hold the b button and the power button for 10 seconds
The LEDs will blink red and white 3 times... You're done.
Fue útil esta respuesta?
This works like magic!!!
When I use a different charger, my pill don't charge or go on. It happened before and lasted a week or two and then it started to work. What's the problem?
I think my charging ports all screwed up because I have to hold the charger a certain way and it doesn't even stay charging long. I don't have original charger either
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 25
Todo El Tiempo: 19,549
