My power button is not working lenovo a7000
I have charged my phone overnight.In the morning i came to see that my power button is not working.Help me out
lenovo a7000
Es esta una buena pregunta?
lenovo a7000
I faccing same problem
help to out me from this problem
Fue útil esta respuesta?
Facing same problem.
Turn on tap to wake from menu. that's how i bypassed the power button bullcrap.
1) Connect your phone to a computer using USB
2) Hold upper volume key for 5 seconds as soon as your phone is plugged in to a computer using USB cable.
3) A menu will appear. Use upper volume key and go to the 3rd option which is " boot normal"
4) Press lower volume key for selecting that option.
Your phone will be switched on automatically.
Restart it just by adding the restart button in the notification panel when you slide down you'll see a 4 dot at the right side.
I have lenovo a7000 I charge phone at night next day phone is not switch on what should I do
Change Sleep option to ‘Never’ under settings, display option. Although this isnt a solution, may temporarily address the problem, at the cost of draining batter
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 14,368
3 comentarios
lenovo a7000 switch solution
- de ali
my phone was not getting charged more than 15% and now it cant be switched on? plz help
- de ankitaprasad3026
What to do if lenevo 480060a2 on off button is not working . And if mobile phone get switch off
- de arun s patil
