Why is my display has a vertical line
why is the display has vertical line
Es esta una buena pregunta?
Bernard Jones, if it is a single vertical line, it most likely is a bad binding (TAB) error on the LCD. Of course you do want to make sure that the cables are properly seated, but my first choice is a bad LCD panel.
Fue útil esta respuesta?
LCD panel. To crush any hopes and dreams of it being the cable, before someone chimes in that it uses the cable, be reminded that displayport is a works-or-doesn't-work protocol. It isn't like LVDS which is based on difference between lines. It's the LCD.
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 24
Todo El Tiempo: 1,440
