Saltar al contenido principal
Aquí puedes consultar guías de reparación para MacBook.
Preguntas 3787 Ver todo
Losing wifi signal on early (Black) MacBook
MackBook CoreDuo, 2GB (upgraded), 320GB (upgraded), latest Snow Leopard update.
If the MacBook is in the same room as the Airport extreme the signal is satisfactory
802.11a
Channel 149 (5Ghz)
RSSI -40
Transmit 24
If I move to another room about 30 feet away, the transmit drops to 1 and I many times cannot access the web. Our other Macbook (White Core2Duo) does not have this problem.
I have read about frayed antenna wires and flaky airport cards - any ideas?
DB
Es esta una buena pregunta?
Puntuación 2
1 comentario
+ nicely stated question
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Doug, I believe you answered your own question. It can be faulty cables or the airport card. Have a look at the cables and try to substitute the airport card with one of the other macbook's cards. Being that these cables are routed through the display housing I suggest this guide. Although its more costly, in this case I would hope it's the card and not the cables being that replacing the cables requires dismantling the display which isn't too much fun, even for a seasoned vet.
MacBook Core Duo Display Replacement
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
I will try that.
Thanks.
- de
+ agreed
- de
+ Ralph
- de
Añadir tu respuesta
Doug estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 2,667
