glass broken. All else works fine
can I change out just the glass or do I need the Assy.?
The glass is less than $10 and the Assy. Is just under $100
On the repair here. It doesn't show info on the LCD removal.
Es esta una buena pregunta?
Jetfixer, sure you can. All you need is an LCD separator and a OCA vacuum laminator and a few other tools. As you can see, unless you have the tools and the experience, I suggest that you replace the complete assembly. Cheapest way to go is to actually let Apple do it for $109.
Fue útil esta respuesta?
of couse you can, but the installation of any new part should be done by a qualified person.
I'm sorry. I was under the assumption we should be able to fix our own stuff. Just looking for a little insight.
you can change the glass lens by yourself. v
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 158
