Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Es esta una buena pregunta?
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 31
Todo El Tiempo: 1,679
4 comentarios
Is the mower turning over at all or is it just a dead mower?
- de Nathan Wells
turning over backfires thru carb
- de allenperkins364
adjusted air gap valves set gap on coil
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
- de meriview@aol.com
