I received the same exact error code: 4SNS/1/C0000008:Ts0P--124
I'm working on a client's MacBook Pro 13" Late 2011 A1278.
I have the same issue. I removed the MacBookPro8-1.plist file from the original folder to bring the laptop to a usable state, but the fan still runs at 100%. I would say that it is still not running optimally (I have removed 13 malware items, but have not completely cleaned the system up).
I noticed some signs of corrosion (liquid spill) on IR sensor (on one of the ends of the Hard Drive Cable). I received the same exact error code: 4SNS/1/C0000008:Ts0P--124. Troubleshot every cable by disconnecting them, however, you can't remove the keyboard cable (as mentioned in the post above) because the power button is connected to it. Tried SMC PRAM resets, etc. To no avail. Also Temperature Gauge App (Trial) doesn't show any fan issues.
I will attempt to replace the Trackpad and let you know how it goes.
Es esta una buena pregunta?
