Saltar al contenido principal
Una videoconsola producida por Sony Computer Entertainment, también conocida como PS4. Anunciada el 20 de febrero de 2013 y lanzada el 15 de noviembre de 2013.
Preguntas 1700 Ver todo
How do I remove and replace the Matte Top cover?
I recently dropped my PS4 onto concrete. The fall resulted in the Top Back Left of the cover to be crushed in, and the Power button to stop functioning. I tested the console and it boots, loads and plays all disks fine. I decided to attempt a repair, but i hit a snag when i couldn't figure out how to take the matte side of the top cover off. I have taken out the TORX T8 security screws (T9 bit fit better though), but the cover just wont budge. Is there a specific way to pry the cover off?
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
5 Respuestas
Solución Elegida
Yes, there is a specific way to get it off...follow these steps (I'm assuming that the one black screw in the back [under the warranty sticker] has been removed along with the 2 silver ones on the top):
1) Put the console up on a table or workbench and get behind it. Pick it up in such a way that you can use your right hand to pull up on the corner where the power button is. Pull up on it several times pulling up a little more each time...you should feel part of it on the back "give way" or come loose.
2) Still using your right hand move over to the left corner. Put your palm on the top of the PS4 and curl your fingers under the lip. Press down with your palm while pulling up with your fingers. This is the hardest part and you may come away with a scratch of even a small cut on one of your fingers if it's especially tight.
3) If done correctly it will pop up. After it pops up you can just pull it off of the back of the case.
I hope this helps...good luck!
Fue útil esta respuesta?
Puntuación 5
7 comentarios:
Thanks a ton! I thought i was going to snap the cover but it came off eventually
- de
Great...I'm glad you go it off...these can be tricky.
- de
Where is the black screw under the warranty sticker I can't find it
- de
I'm not sure why you can't find it...it's just right under the warranty sticker. Maybe the factory forgot to put it in!
- de
I can't find the black screw under the warranty sticker. Where is it?
- de
Mostrar 2 comentarios más
I tried this and my power button no longer works.
Puntuación 1
1 comentario:
If your power button doesn't work then the cover either needs to be snapped down in place fully or there could be a problem with the metal contact that goes from the plastic cover to the copper pad on the motherboard.
I would try to give it a good push down where the button is and if that doesn't fix it then you may have to take it back off and have a look at the metal contact piece.
I hope this helps.
- de
I satill have 2 months warranty. If your like me you got your Playstation 4 in Dec. also. I'm thinking instead of me cutting myself, I'll just replace the unit using my warranty
Puntuación 0
1 comentario:
I would definitely use the warranty since you have it.
- de
how can i remove the back nail from the top
Puntuación 0
How do I remove the hard drive without Sony’s special screw?
Puntuación 0
2 comentarios:
I saw you can use a tiny flat head if you swine small enough that is
- de
*can find not swine
- de
Añadir tu respuesta
Haybale100 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 75
Todo El Tiempo: 63,681
