The sound bar is not turning on.
The remote is working but I don't know what wrong with it, is there a fix for it?
Es esta una buena pregunta?
Sounds like you are having the same issue as me, the problem is faulty capacitors. You can either replace the capacitors yourself if you know how to solder or send it in to a Sony certified repair center to get your pocketbook gouged out.
Fue útil esta respuesta?
Benoit, do you recall specifically which capacitor it was? None appear to be bulged or visibly bad that I can tell . Id rather not have to test each one if it's not necessary
When I press the power button on remote only 1 light comes on. The light where it showed surround sound on the sound bar. For about 2 seconds then goes off.
I've tried the reboot and nothing.
Is there a fix for this?
Thank you
Tom
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 4,813
