Saltar al contenido principal
Cámara de 18,2 megapíxeles de Sony diseñada para la toma de fotografías en general, imágenes en 3D y filmación. Número de modelo: DSC-WX100.
What might be causing the screen to be dim?
The screen, even after the camera has indicated to be fully charged, is dimly lit. This is despite have the screen brightness at the highest setting. An image is still visible, but glare is an issue in both natural and artificial light.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The first thing you should try in this case is to check the LCD screen brightness settings on the camera. If the brightness setting is too low then the LCD screen will appear dim. Go into your camera settings to change the backlight brightness. Another case is that the backlight bulb is dead, thus you'll need to go disassemble the camera to first get to the bulb, and then replace it. Other details for this issue can be found on our troubleshooting page.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Peter Prins estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 2,102
