Phone will not power on
I disconnected my iPhone 6 plus from the charger and as soon as it was disconnected the phone turned completely off and now won't power back on.
Es esta una buena pregunta?
Fist check to make sure the phone charged when you had it connected and charging. It may just be that it never charged.
If it's charging, try a hard reset, press and Hold down the home button, & the power button at the same time, until you see the phone turn off, and come back on and you see a black screen with a white Apple logo. Then let off both buttons. It will go back to normal if that worked.
If not, connect to iTunes via PC using A USB cable and try doing a Restore and back up
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 385
