My vacuum is not picking up dirt, what could be the problem?
I've tried cleaning out the filter but I'm still having problems.
Es esta una buena pregunta?
If your Shark Navigator Lift-Away Pro no longer sucks up dirt, dust, and debris, see the Shark Navigator Lift-Away Pro Loss of Suction problem page for possible causes and solutions.
If your Shark Navigator Lift-Away Pro no longer sucks up dirt, dust, and debris using the vacuum’s nozzle, see the Shark Navigator Lift-Away Pro Loss of Nozzle Suction problem page for possible causes and solutions.
If your vacuum is still not picking up dirt, there may be a blockage either in the brush roll, the hose or the hose that leads to the dust cup. If your hose accessory isn't picking up dirt, detach the hose and check for blockages in the hose and the place where the hose attaches. You can also check and clean the dust cup. If none of these solutions work, your motor may be going bad.
Fue útil esta respuesta?
Hose is bendable, metal. Wand attachment is not, and that is where the blockage is. Do I take meta l hose apart?
I read through all the comments and people used an opened up wire coat hanger to reach up into that area to remove the clog....have you tried that? It might be worth the try.
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 85
Todo El Tiempo: 10,450
The sweeper is not picking up. There is one hose that we can’t push anything thru.
- de raidenbaum
My shark is spitting out the dirt - not picking it up
- de jan.durn
Mine too! I got it for Christmas! Help please.
- de jo.logan
