Why isn’t my touchpad working?
When I try to touch or click the touchpad it doesn’t respond, which is really frustrating because now I can’t navigate around my computer.
Es esta una buena pregunta?
Hi Aaron,
You may have just accidentally disabled the touchpad. To check if this is the case, look for a button located above the F7-F12 keys. It’ll look like a square with a hand and a plus sign, if the red light is on, then it’s disabled. To fix this, simply press it again to turn it off. After that your touchpad should be working again.
Hope this helps!
Fue útil esta respuesta?
Thanks a lot Stephen! I had the same problem and now it's solved. Actually i posted the same question yesterday but remains unanswered. I didn't have the chance to check on he posted questions/answers before I posted my question. Thanks a lot again! You made my day.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 143
