Saltar al contenido principal
Estación base Apple AirPort Extreme de cuarta generación (número de modelo A1354)
Preguntas 18 Ver todo
wan port not detecting internet provider
my airport extreme suddenly stopped working. I can get internet through the ethernet cable direct from provider modem to my computer but not through extreme. I have tried reset and factory reset with no success. The LED indicator on the WAN port indicates it is working but no provider is being detected. If this is a hardware problem does anyone know of a possible repair.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
2 comentarios:
What does Apples AirPort Utility tell you?
- de
Did you get things working?
- de
Agregar un comentario
1 Respuesta
Apple AirPort Extreme is a simple fix, it is either the antenna or the WiFi card.
if the WiFi light is on it most likely to be an antenna, you can get one off ebay for pretty cheap
here is the guide to fix replace it.
Apple AirPort Extreme Model A1354 Antenna Replacement
if you need to replace the WiFi card, here is the guide for that.
Apple AirPort Extreme Model A1354 WiFi Card Replacement
Imagen de Apple AirPort Extreme Model A1354 Antenna
Guía
Dificultad:
Moderado
5 minutes
Imagen de Apple AirPort Extreme Model A1354 WiFi Card
Guía
Dificultad:
Moderado
10 - 15 minutes
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
wmathie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 1,118
