Blinking green light why?
Had a sudden loss of power or signal with drone it fell and broke cross section. Can't connect wirelessly or via usb. Just getting blinking green light which usually means motors out.
Any way stripped it a little and found white motor power plug completely disconnected. Unsure if this occurred on impact or worked loose causing motor stall.
Great thinks I. An easy job. Puts connector back firmly in place and checks all gold antenna connectors are seated and in situ.
Puts it back together and its the same. Giving off no wifi signal to connect to for diagnostic tests on motors.
Any one any clues? Could mainboard be toast.
Es esta una buena pregunta?
15 comentarios
Is it normal to be unable to connect via wifi or pick up the drone via a pc to usb connection with the drone when a motor failure occurs. Someone must have experienced similar issues. I understand diagnostics tells you if a motor is not running correctly but I can't connect so unable to diagnose issue. It did come down on one motor strut which I assume then sent the energy into the cross section which fractured.
- de stu
i have the same problem, green LED light keeps blinking
- de asghar30
Hi I was told to disconnect all motors and see if that brings it back to life if it does then a motors broken. It didn't work for me.
Mine was a shorted mainboard. I sent it off for repair and after a reflash it came back to life, the fan was replaced and a motor and cross section replaced. Whole lot cost me £80 Gbp.
- de stu
Hi stu where did you send it for repair I have the same issue
- de Dan
Southend on sea in Essex. Was given guys details by Parrot. Are you UK based dan.? I can't put his email on here because of spammers. Basically the guy charges £15 for diagnosis of the problem and that includes return postage in the UK. If your happy with him proproceeding he gives you a price and if your ok with that you paypal him money and he proceeds. Alot cheaper than buying a whole mainboard if its an individual component out on the board. Heres there website. Use contact us section. http://custemz.uk/
- de stu
Mostrar 10 comentarios más
