What is causing the horrible sound in my Kenmore 2600 dryer?
My Kenmore 2600 dryer sounds like a bearing or something metal is rolling around inside it.
Es esta una buena pregunta?
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Maintenance Kit
Dryer maintenance kits typically include everything needed to rebuild the dryer with common to fail components. This way the dryer can be disassembled one to to repair.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Idler Pulley
If your dryer is making noise the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
Idler Assembly
If your dryer is making noise the idler assembly that puts tension on the dryer drum drive belt could be worn out. If the idler assembly is bad we recommend also replacing the belt.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Fue útil esta respuesta?
Well, the highlighted answer is pure garbage. Oh, it’s a rumbling noise? Okay then there are 12 out of these 15 possible issues it could be. Replace all the things. -_-
I found this answer enormously helpful. Specifically, it helped me identify the noise in my dryer as coming from the blower wheel enclosure, and then to recognize that the blower wheel sleeve might be worn out. Having just completed (God willing) this repair, I can add that with the captive nut design of the blower wheel, removing the blower wheel with the nut slipping inside it is a mammoth and unpleasant task, involving drills, hacksaws, screwdrivers, tin snips, and anything else I could get my hands on. Again, though, I believe I've now successfully replaced the blower wheel. Thanks!
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 22,295
