upgrading battery from 2800 mamp to 3200 mamp
is i can upgrade a battery with more power for my tab ?
Ex: 2800mamp to 3200 mamp ?
Es esta una buena pregunta?
Mohammed Buhari sure you could if you can find one that fits your XTouch. Be aware of the scam with higher capacity batteries etc. Most of those are not any better than the standard batteries. You can try and search for a better battery based on the physical size of yours as well as the connector. Check reputable sellers only. Check this El mito de las baterías de "alta capacidad" since it is still true today. Remember, higher capacity batteries also take longer to charge
Fue útil esta respuesta?
Now Why? How do you upgrade a Battery’s MAH
IS A BAD IDEA TO DO IT!
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 196
