Saltar al contenido principal
Máquina de algodón de azúcar de sobremesa para usar con caramelos duros o azúcar de caña. Modelo PCM805 / PCM805RETRORED
Why doesn't the device spin when powered on?
When candy or sugar is placed into the device and it is turned on, the device does not spin like a cotton candy machine normally should.
Es esta una buena pregunta?
Puntuación 3
4 comentarios
Yes, we had this problem too. The whole family was involved in disassembly. (Darn cheap screws all stripped though! What a pain!) We got all the way down to the motor and found that a metal piece had come off the post on which everything spins. We tried a few different options to keep it attached, but adhesives didn't seem to work. And even when it did seem to hold together it wouldn't spin well. After many attempts we threw the whole thing away. I would like to replace it with something more well made.
- de
I have "the real cotton candy maker" when I try to turn it on, it stays on for a minute but then shuts off! I've been trying to figure it out for 2 days! What do I do?!
- de
i have ‘The Real Cotton Candy Machine’ and i accidentally turned it off before it stopped by itself and now it wont turn on any suggestions?
- de
Same crap happened to me, I think it's just a PIECE OF JUNK!
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Hello,
If your device has power but it still does not spin, it is likely that you have a blockage obstructing your device. If your device has been used without being cleaned it is possible that residue is stopping your device from spinning. Properly cleaning the extractor head can resolve this issue.
If the extractor head is clean but it still does not spin, the motor may have gone bad. Your best course of action is to buy a replacement.
Follow this link for additional help Nostalgia Electrics PCM805 Troubleshooting
Carlton.
Fue útil esta respuesta?
Puntuación 3
It will not spin and I need it to
Puntuación 0
Mine is not spinning either, the center leans to one side.
Puntuación 0
Añadir tu respuesta
Nicholas Fazio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 52
Todo El Tiempo: 25,311
