Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un lector electrónico portátil desarrollado por Amazon. La reparación es sencilla y solo requiere herramientas de palanca y destornilladores.
Can the USB socket be replaced without replacing the motherboard?
Es esta una buena pregunta?
Puntuación 7
2 comentarios
This is for the kindle paperwhite.
- de
I can’t recharge the battery .The yellowflashes intermittentantly as I wobble the recharging cord seemingly there is a connection problem.
What do I have to do to restore the charging capacity.?
Have tried several recharger cords.
Your advice would be welcome.
Thankyou
Mairin Campbell
- de
Agregar un comentario
1 Respuesta
Solución Elegida
The USB socket is soldered to the motherboard, so it can not be easily replaced without replacing the motherboard. In theory the socket could be replaced with some careful soldering work if you could get your hands on a replacement socket. For someone experienced with replacing small components on circuit boards I'm sure it would be possible, but if you are a beginner with this sort of thing you may do more damage to the circuit board by overheating it. Look closely at the photos in this guide before deciding to try this repair.
Fue útil esta respuesta?
Puntuación 8
Añadir tu respuesta
Tom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 25
Todo El Tiempo: 2,141
