Saltar al contenido principal
Pantalla de 7.9 pulgadas / Modelo A1454 / Disponible en blanco o negro / Anunciado el 23 de octubre de 2012/16, 32 o 64 GB de capacidad
Restoring a jail broken ipad
my iPad was jail broken, I would like to restore to its original state
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi Peter,
- Backup: back-up your data using iTunes, and as an added measure, manually copy your photos and contacts(or anything you deem important) to your laptop using iPhoto and/or iFunbox for example. Or sync everything with iCloud. I say that because sometimes backed-up data of jailbroken devices is corrupted and cannot be restored.
- Restore mode: turn off your iPad. Connect it to your laptop. Start iTunes on your laptop. Now press and hold power button + home button together for ~12 seconds, then release power button but keep pressing home button for ~15 seconds. iTunes should now say it detected an iPad in restore mode and prompt you to download and install the latest software. Accept, and leave your iPad connected and undisturbed until it finishes the download and restore which could take long if you have a slow Internet connection (the file is ~1.5GB).
- Once done, your iPad will restart with the new firmware. You can choose at this point to restore the back-up or manually syncing data back to your iPad.
Good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Peter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 299
