Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de reparación para teclados de computadora que no son de Apple.
How to repair charging port?
When I last went to plug in my micro USB charger into my Zagg universal Bluetooth keyboard, the charging port was pushed further back into the keyboard. How do I take it apart to repair this device? There are no visible screws anywhere.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
4 Respuestas
Respuesta Más Útil
I just took mine apart. Use a heat gun to soften the adhesive, and slowly remove the rubber, then the case will seprate. The mirco USB connector is weak, and I have had several fail already. this part would otherwise be easy to replace, as it clips on, but Zagg will not sell the part. I may try to bypass the port, and charge directly to the battery...
Fue útil esta respuesta?
Puntuación 1
Not sure if this will help but here it goes. The connection was very loose and cable would fall out. The port was not loose, just seated far back. I took a file and filed down the cable plastic on the connector so it angled properly in relation to the case and port. Problem solved.
Puntuación 1
Bought a new keyboard after mi puts roba
Puntuación 0
it broke off during normal use plus the wand has stopped working
Puntuación 0
1 comentario:
were do i buy new keyboard and wand
- de
Añadir tu respuesta
Lucas estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 5,595
