iPhone 5 itunes stuck at "waiting for iPhone" screen
I got this iphone from a customer, when he gave it to me the screen was not working but the device was found by itunes. He told me he had lost it in the snow and after that it didn't work.
So the first thing i did was to open it and see if the water indicators was red. but they waren't. Not a single one of them were red.
So then i tried replacing the battery and the screen with no luck. The phone were still not showing any picture on the screen.
So then i decided to connect it to itunes to see if i could recover it, and then the screen started showing the apple logo. But the itunes screen wouldn't go pass "Waiting for Iphone".
I hope someone have sulution for this, i have tried everything and i can still not get it to work. I tried with a couple of different usb cables so i dont think that's the problem
Regard
Mr Jakobsen
Es esta una buena pregunta?
Hi.
I got the phone back from the customer, and i cleaned the motherboard with IPA and preformed a ultra sonic cleaning. But after I reassembled the phone it wont turn on at all...
por Vegard Jakobsen
Do you see any missing/corroded components? If yes, where?
Did you remove the shields? It is both easy if you know the proper way to do it and have the tools, and hard if that's your first time, and you risk knocking components off.
por Rany
i removed the heat shields using a heat gun, and then i first tried soaking the bord in IPA, and afterwards i used a ultra sonic cleaner machine to clean the board, and then i placed the phone in a container of rice to dry it up.
But i couldn't see any corrosion or missing components, neither before or after I preformed the water damage repair.
Thanks.
por Vegard Jakobsen
