Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Airport Time Capsule es un enrutador inalámbrico y un dispositivo de almacenamiento conectado a red (NAS) fabricado por Apple. El modelo A1409 es la cuarta generación de la Time Capsule, lanzada en junio de 2011.
Replacement HDD larger than 2 TB?
What is the largest HDD I can use in my AirPort Time Capsule 802.11n (4th Generation)?
Current HDD is causing problems and is running out of space (2tb) looking to put in a 3tb or 4tb if available.
Make and models recommended would be a great help too
Es esta una buena pregunta?
Puntuación 17
6 comentarios
md032ll/a a1409
- de
Hello
Has anyone tried to use wd red drives yes I am considering trying a 6tb red drive suggestions please ....thanks
- de
i have used several wd red drives,,,very good drives
- de
does it take SATA drives ? or is it IDE ? it’s pretty that is why i ask
- de
Data works best didn’t use ide too outdated for my tastes good luck.
- de
Mostrar 1 comentario más
Agregar un comentario
8 Respuestas
Solución Elegida
Here'a a nice guide on how to do it: http://www.maclife.com/article/howtos/ho...
Fue útil esta respuesta?
Puntuación 10
2 comentarios:
This guide is basically ok. There are only two additions I would suggest:
1. Use a hair dryer to cautiously heat up the base rubber, and lift it up starting at one corner. This prevents the rubber from being ruptured.
2. Disconnect the inner fan cable from its socket. It is helpful to have the housing of your TC separated. Don't forget to reconnect! ;-)
- de
Nice Solution .. great solution :)
- de
Respuesta Más Útil
Yes, you can. The A1409 contains a standard WDC Green 2TB HDD. I used the existing repair instructions to replace this with a WDC Green 4TB HDD - exactly the same except double the capacity. When the Time Capsule restarts you get an error message in Airport Utility saying the "Disk needs repair". Click the error message, then hit "Erase" and Airport Utility formats a 4TB partition on the new HDD.
Puntuación 15
Hello there...
Just replaced my 2tb drive with a WD 6tb NAS red. Works just fine.
Regards to all
Col
(aka VK2CRT)
Puntuación 9
I have the same model Time Capsule and I just upgraded the hard drive to a Seagate Enterprise Series 5TB, 7200 RPM drive. It's lightning fast and has plenty of storage.
Puntuación 8
Can anyone suggest the best hard drive to use to replace the original? How large a hard drive can I put in one of these? Thanks in advance!
Puntuación 0
A 6TB WD Gold WD6003FRYZ is working like charm. Only had to reformat the drive after replacement. Thanks for the HDD replacement guide.
Puntuación 0
Can I partition a Time Capsule ?
Puntuación 0
I replaced the stock HDD of WD30EZRS 3.0TB with Seagate 8TB IronWolf Pro ST8000NE001. My A1409 with 8TB HDD have worked fine~!
Puntuación 0
Añadir tu respuesta
mockingbird1313 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 27
Ultimos 30 días: 78
Todo El Tiempo: 35,157
