How can I check the disk drive?
Is there a way to check if the HDD has failed? I get Fanfare and a flashing question mark.
Es esta una buena pregunta?
Turned out to be a loose HDD connection.
Fue útil esta respuesta?
Start up holding down the Command & R keys: http://support.apple.com/en-us/HT4718
Thank you for the input.
I started a tear-down again and found the HDD connection popped loose when I re-installed the WiFi antenna. There's a tale of caution!
Steen Rancher
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 153
