My bet would be the Pulley or Drive Pulley. If you give us the model number I can probably find the part.
Tub Bearing
If the washer is making a loud noise the tub bearing might need to be replace. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Tub Seal and Bearing Kit
If the washer is making loud noise the tub seal and bearing kit might need to be replace. This is a very involved repair and will require disassembling most of the washer. If the bearing is bad the problem is going to get worse very quickly and so either the tub seal and bearing kit will need to be replaced or the washing machine.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
5 comentarios
I have very deafening loud banging noise ,dish hitting the wall of washing machine only when spinning,washes normal.
- de kkoeget898
The drum assembly should move, but not hit the cabinet. The dampers/shock absorbers should restrain it. They wear out, can either bind or move freely instead of providing even resistance. Check them. They are cheap and relatively easy to replace, though you may need to remove the back panel to reach their attachment pins to push/pull them out.
- de P Schmied
I am using IFB 8 kg washing machine . It makes big sound while spinning. Can it be repaired? Or I need to replace drum itself? What would be the cost?
- de Deshpande KrishnaG
Exactly what happened to my last machine. It was un economical to repair as it was about 8 years old. It was cheaper to buy new.
- de Dean Beddall
My Indesit(Mod no - XWE 81283) is deafening loud banging noise ,dish hitting the wall of washing machine only when spinning,washes normal . Plz give me a solution.
- de Sarder
