Saltar al contenido principal
La Canon PowerShot es una cámara de 5,0 megapíxeles con zoom óptico de 4x.
Preguntas 14 Ver todo
Broken ZIF Retaining Clip on CCD Connector
I'm trying to replace the CCD and broke the retaining clip on the ZIF connector.
It's a 28-pin connector with approximately 0.381mm pitch.
Does anyone know a part number or manufacture so I can order a new one and swap retaining clips?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I fear you've got quite a challenge there. If you can find a supplier you may find the website is in Japanese or Chinese with a minimum order of 1,000! Your best bet is probably to put a watch on eBay and you may be able to get another A610 cheaply perhaps with a different fault from which you can cannibalise the apropriate part, or the whole logic board so as not to risk damaging the clip in trying to transfer it.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Bob Peters estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 172
