How to fix touch after screen replacement?
I changed the front screen on an iPod touch 5th gen and the screen works fine but it's unresponsive to touch! Anyone know how to fix this?
Es esta una buena pregunta?
1/ Assuming that the touch function was working before your replaced the screen:
Disconnect the screen cable from the board. Clean the connectors with isopropyl alcohol 90%+ if you suspect they are dirty or just to be safe.
Then reseat them gently, but make sure they are properly connected. Hard-reboot and try your iPod.
If it still doesn't work, you could be using a defective replacement screen, or may have damaged it during installation.
2/ If the touch function was not working to begin with, even before you tried replacing the screen the first time, try a hard-reboot just to be on the safe side. If no change, then you could have a problem on the logic board that needs some special skills and tools to find and repair.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 320
