Is battery easy to be replaced?
Is it possible to carry a backup battery on road and use a simple tool, like screwdriver to replace the battery for extended use? Thanks!
Es esta una buena pregunta?
when you look at the teardown - you will see that the battery could be easily removed - but i would not do that. it looks fragile and i would prefer a mobile charging solution, i have a emergency charger that is powered by an AA battery - works great. this charger could easily modified to charge an iPhone
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 915
