Saltar al contenido principal
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Preguntas 459 Ver todo
How to diagnose dead board of Galaxy SIII?
I was having problem with my USB charging connector and changed it, but now the phone is completely dead and does not power on nor does it charge or show anything on screen. The connector is fixed properly but still nothing works seems the board is dead. How to diagnose the problem?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
First check the battery voltage with a multimeter. If the battery is less then 3.8V, try to charge it externally.
When you have a charged battery, try to switch-on it. If the phone switch on normally then you have a problem with the charging.
If the phone can't switch-on, try to enter the phone into Android System Recovery menu or in Download mode (Volume Up+Home+Power or Volume Down+Home+Power). If you can enter this modes, maybe the problem is into the SW. You can reset it from the Android Recovery menu or to reinstall the firmware from the download mode. The battery must be at last 80% charged!!!
If no, try to connect the phone to the PC by holding the volume down button.
If the battery is charged and if the Windows can't recognize connected device, then you have a hardware problem.
Regards.
P.S. You can buy a JIG dongle for entering Download mode for Samsung Galaxy S3 or you can find easy in the internet how to make it by himself.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Huzefa Darolywala estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,265
