Saltar al contenido principal
A compact version of the HTC One, released August 2013.
Preguntas 32 Ver todo
Powering on with a broken power button
Hello guys, I've been having kind of a big problem with my HTC. I dropped it a few times and the casing tore away from the top part and the bottom part of my phone, including the power button. normally I'd just get a new casing so I could use it, but the mechanism itself tore off too, meaning that getting a new button or casing won't really fix it.
I was wondering if there is a way to boot up my phone through my pc. I've been searching around and it seems to be fairly simple for most Android phones, however, since HTC One's block your access to the battery, I cannot use any of the tips others give me.
I do not have warranty anymore, so I'm not afraid of doing the bigger things. It is also rooted.
Right now, the phone is still on and I wake it up by using lock widgets and using the volume button. I am however still scared about not being able to charge it on time to keep it alive.
Thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
i am in your place but it had turned off
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
it's pretty easy if i remember right that power button does not require soldering so just order a new part and pop it in.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
as in disconnect the old broken one and connect that one.
- de
how to reboot my htc one mini not working my power botton
- de
Añadir tu respuesta
Alperen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 3,362
