Saltar al contenido principal
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Preguntas 149 Ver todo
Broke LCD PCB connector, no display, device still powers on
I accidentally broke off a small portion of the M7's LCD PCB connector (not sure what is the correct name for this).
I put everything together again, it still boots, but does not have any screen. Fortunately I can still use ADB so most of that side appears to be working fine.
Upon closer inspection, it looks like one of the connector pins are missing from the connector:
I am not sure how to proceed from here - is it possible to get a donor board and replace this part, or do I need a new board?
Thanks for your response!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Vic, yes you will have to replace the connector. If you have the tools and the skills to do some very fine soldering, you could do a transplant from a donor board. If you do not, you know you will need a new board.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Vic estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 263
