Saltar al contenido principal
Un portátil fabricado en 2003 por Toshiba.
Preguntas 4 Ver todo
Why will my device not power on?
The laptop will not power on with battery in. The device still does power on when the power adapter is connected.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
The problem could be related with your power adapter or your battery. On your power adapter, The first component to check is the 2 cords one that connects to the wall and adapter to computer. If the computer doesn't start whit the battery on, the battery is faulty.
Please follow our troubleshooting page. It can help you to check what is causing you problems.
Toshiba Satellite 1415-S105 Troubleshooting
Also, you can check our guide to see how to replace your battery.
Sustitución de la Batería del Toshiba Satellite 1415-S105
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Jason Hofstetter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 320
