Saltar al contenido principal
Tefal Actifry - Cocina de convección. Esta revolucionaria y versátil freidora te permite cocinar una amplia gama de comidas de forma económica y también es más segura y fácil de limpiar que otras freidoras.
Replacing the heating ellement
Replacing the heating ellement in a Tefal Actifry
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario:
The paddle stopped turning on mine and after fitting a replacement motor the heater and fan did not work but the paddle did. After careful examination of the circuit board I noticed that the larger of the two fuses had blown. It looks like an antisurge fuse and it was very difficult to see if it was blown but my meter confirmed it was U/S. Unfortunately the fuse needs to be desoldered and a replacement soldered back onto the circuit board. All good afterwards. Tefal need to think about their philosophy and try to make stuff that lasts longer than 12 months and is also easier to repair.
- de
Agregar un comentario
1 Respuesta
follow the guide for the paddle motor, the heatin element module can be prised out gently using a screwdriver and the 2 black leads removed from the PCB board.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Mike estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 3,521
