Saltar al contenido principal
Lanzada en línea el 16 de enero de 2009, la Inspiron 1545 es un portátil económica de 15,6" disponible con 3 o 4 GB de RAM. Sucedió a la Inspiron 1525.
How to upgrade the HDD with a 7 mm SSD drive?
I have an Inspiron 1545 with its original HDD drive and I want to replace it by a new SSD unit. The main problem is that the original HDD has a height of 9.5 mm and the newest SSD units (like the Samsung 840 Evo) has a height of 7 mm. I know for several post in the web that the solution is to buy and attach an "SSD Spacer" to the disk. This piece of plastic ensures that the SSD will be recognized by the Laptop BIOS, but the problem is there is not a step by step guide that shows how to do it in the right way.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Nothing magical here just a mechanical spacer to lift the drive up.
This spacer goes under the drive to lift it up so the SATA cable location is at the same level as the 9.5mm drive would be. If is not done the stress on the cable/connector mating can cause a bad connection.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Miguel Angel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 2,025
