Saltar al contenido principal
El Samsung Gear Live es un reloj inteligente con Android anunciada y lanzado por Samsung y Google el 25 de junio de 2014.
The charging cradle broke. Can I replace it?
The charging cradle on my Samsung Gear Live broke. Are replacements available or can it be repaired?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
A chips bag clip works just dandy.
- de
يرجى توضيح أكثر هذا قليلا
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Had issues with mine, little plastic snap opposite of button side of device.
Fue útil esta respuesta?
Puntuación 2
In the event of your Gear Live's charging cradle breaking, replacement is your only option. Unfortunately, the charging cradle's design does not facilitate repair, so that option is unavailable.
Puntuación 0
It's worth noting that at this exact moment there appears to be no way to replace it. Samsung will just refer you to Google, and Google says the cradle is "coming soon".. and has for a while now. (https://play.google.com/store/devices/de...)
In short, Gear Live owners are stuck with a charger that easily breaks and can't be readily replaced. Boo.
Puntuación 0
The easiest way to get around this that I have found with my own broken gear s charger is that you can use a pill bottle. Simply close your watch strap in the locked position place the charger in position, and use a pill bottle to keep enough pressure on it to charge. Make sure the bottle is not too large so that you don't over stretch your band. I did this because I was leary about buying another charger, knowing that the new one would probably break as well in time.
Puntuación 0
You can get replacement charging cradle easily on Ebay and it works fine.
Puntuación 0
Añadir tu respuesta
Keith Cooper estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 3,726
