Saltar al contenido principal
Netbooks también necesitan reparaciones, mantenlos al dia con nuestras guías.
Screen replacement for Nextbook 8 NX785QC8G
I recently dropped my Nextbook 8 and the Digitizer broke, I need to replace it but I don't know how to take it apart since it has no screws on the outside. I also need a link to a new digitizer screen because I'm not sure as to which one it needs. Thank you for your help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 14
1 comentario
Where can I buy a screen for it
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
You could buy a new digitizer from ebay
New-Digitizer-Touch-Screen-Panel-For-Nex...
Fue útil esta respuesta?
Puntuación 3
if you look at the edge of the tablet there's a seam. you want to get a really tiny screwdriver and slow try to open it. when you hear a pop that means the clips on the inside have released and you want to do that all the way around the side of the tablet.
By,Jahn Peabody
Puntuación 2
1 comentario:
After I put it back together the touch screen is not working and it w
as before. No I have not replaced the screen as of yet.
- de
I think I'm having the same problem. Dropped my nextbook and it is cracked across the screen. It's crack left to right at the middle of the tablet. I can't use the top portion because the touch screen isn't working on the top. Bellow the crack it's fine. How would I go about replacing it when I get the screen replacement?
Puntuación 1
Yes how much it cost to replace it
Puntuación 0
How to fix the part were the charger goes into the nextbook
Puntuación 0
Añadir tu respuesta
Alexander estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 5,930
