Why is my laptop over heatting?
Every time I use my laptop, it gets really hot! Is this a usual thing with laptops? How can I fix it?
Es esta una buena pregunta?
A overheated laptop is usually caused by a clogged fan and heatsink, the solution is opening up the laptop and taking out the fan then you can get to the heatsink get a can of compressed air [blow-off] and clean both thoroughly it should fix the overheating.
Fue útil esta respuesta?
When a laptop is used for long periods of time, the battery becomes worn out and causes extreme heating when constantly charged. To alleviate this issue, try using the laptop without the charger plugged in. If heat is still produced, remove the battery and run the laptop on AC power. Lastly, if all else fails, you might have to buy a replacement battery, which you can order right from the Dell website:
http://accessories.us.dell.com/sna/produ...
Hope that helps!
One suggestion is to use your laptop not directly placed on your lap, or even avoiding putting your laptop on a bed, couch or chair directly. It is a LAPtop after all, right? Why shouldn't we use it while curled up in our favorite chair or on the couch snuggled under a blanket or in bed?
The biggest reason to have something like a laptop desk, (a flat sometimes wood or plastic surface towards the bottom of the laptop), or a laptop rest that has either passive, (no fans), or active, (spinning fans), is to allow the air to freely circulate around the intake ports and the exhaust ports to allow air to cool the internal components of the laptop.
The two previous mentioned reasons for over-heating are correct and good reasons that laptops over-heat. We keep these portable devices we own tethered by always having the power supplies attached and charging the battery. The heat produced by constantly charging the battery when the battery is fully charged, or when the vents are blocked will also shorten the life of the battery and the laptop might become hot enough to damage other internal components. Dust is a big killer of laptops and, (almost more so), desktop computers.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 303
