Saltar al contenido principal
La línea actual de iPod Touch comprende siete (7) generaciones diferentes.
Preguntas 2619 Ver todo
Home button is stuck in pressed position
Hi,
I have an iPod Touch where the Home button is stuck in the pressed down position. The device still works normal though but it's annoying because I have press the button hard every time I want to return to the Home screen.
I was wondering if there is a way to 'unstuck' the button.
Thanks!
Steven.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
First the home button i had to press hard and now it doesn't work at all. Is there anyway I can fix it without buying a whole new one or it costing a lot of money. It's in great shape and I haven't had any other problems with it.
Fue útil esta respuesta?
Puntuación 1
You don't specify which model you have. That makes a big difference as to how to fix it. If you have the 2nd or 3rd generation I'd just recommend you buy a whole new front. You'll get a brand new scratchless screen, and it costs $10. It can be done in 15 minutes by someone experienced, or in 45 minutes if you've never done it before.
If you don't want to take it apart you might try getting an X-acto knife (http://www.amazon.com/X-ACTO-Series-Knif...) and working around the edges of the button to try to get it to pop back up. But if something is damaged inside it might be better to replace the button itself or just replace the whole front.
Puntuación 0
Añadir tu respuesta
Steven estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,264
