Why some keys not working
some keys of keyboard not working
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
5 comentarios:
same problem occurs on the lenovo ideapad 110-15isk
the H and G keys dont work along with the " and esc and some other command keys, is there any fix to this problem please tell me!
- de
If some keys do not work properly on your laptop (for instance, C, M,Q,V keys do not type at light touching - you must press them hardly and longly - some 3-7 seconds), then all suggestions to reinstall the keyboard driver and so on are rubbish.
The solution is as follows: Just open the bottom of your laptop, remove the battery (or lift it) and unfold the soft bands under it (or fold them otherwise).
I had 2 Asus laptops of different models and that action resolved the problem in both. Usually that problem arises 3-rd year of laptop's use
- de
Hi osama nasr,
Wich keys are not working? Could you be more specific?
Bye!
- de
having same issue the g and h keys not working and track pad intermidently stops untill i press a key
- de
the keyboard touchpad should stop working while keys are activly being pressed,
- de
Agregar un comentario
